![]() | Home > General (L405) > White Smoke From exhaust. |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Condensation from the exhaust? |
GregMilner Member Since: 08 Sep 2013 Location: Perth Posts: 54 ![]() ![]() ![]() |
I had this problem with my previous car, a RRS 3.0TDV6 - clouds of white/blue smoke on acceleration, it was embarrassing. It was under warranty, the dealer/LR spend 6 months trying to fix it (they put it down to a turbo problem with that 2010 model year), eventually they gave up and shipped a new engine out from England.
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 ![]() ![]() |
There is s TSB on this. LTB00524v3 - 4.4 SDV8 Exhaust Smoke |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Thanks guys I will pass on the info in the TSB, the car is going in next Wednesday I will let you know how it goes. |
HI guys turbo oil scavenge line modification carried out no more smoke nice going JLR I can not fault their service |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
kudos to Matt for supplying that TSB. |
Hi guys the white smoke has appeared again, Had a little look under the car and found oil just below the L/H turbo where the turbo joins the exhaust connection , so its back to the shop for the turbo this time to be replaced and the front suspension struts as they are knocking and rattling when one wheel hits an irregularity in the road surface. The dealer had to get JLR to approve the repairs first. Will let you all know how this goes. |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
bang on front is the ARC not the struts , its a known issue Far to many gone... |
Thanks thoner001 your info is just great, otherwise they like to blow smoke where the sun don,t shine. Knowledge is a powerful tool. |
