![]() | Home > In Car Electronics (L322) > Sat Nav Draining Battery ???? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34982 ![]() ![]() |
when you switch off the ignition and lock the door ,does the light not go off after about 15 minutes? |
coasterburner Member Since: 03 Jan 2014 Location: Crewe Posts: 13 ![]() ![]() ![]() |
Thanks for the clever thought . Will go out and try it now . |
Just been out to it after an hour . Red light still lit . Any settings I'm missing perhaps ? |
i'd take out the nav unit [as it was before] and see if that rectifies things .. |
Unplugging it did the trick last night . Should I send it back to the ebayer I had it from do you think ? Thanks , Ian . |
seems to be the cause doesnt it.....try and get your money back and go for the dvd based mark 4 nav unit... |
Thanks very much . Will do . |
Looked around and everybody states that the YIB000080 is the upgrade for my car . Have bought one but fittings are completely different . What next ? HELP !!!! |
