Home > In Car Electronics (L322) > Sat Nav Draining Battery ????
coasterburner
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
Hi . I have just purchased a second hand mk.3 sat nav to replace the one missing when I bought it . It seems to stay live and lit up even when the ignition is off . The battery is flat every couple of days . Does anybody know if the nav should work with the ignition off ? Is it the fault of the cd unit or does the fault lay elsewhere ? HELP !!!!!
Post #237456 27th Jan 2014 3:16pm
when you switch off the ignition and lock the door ,does the light not go off after about 15 minutes?
Post #237457 27th Jan 2014 3:26pm
coasterburner
Thanks for the clever thought . Will go out and try it now .
Post #237466 27th Jan 2014 3:51pm
coasterburner
Just been out to it after an hour . Red light still lit . Any settings I'm missing perhaps ?
Post #237476 27th Jan 2014 5:00pm
i'd take out the nav unit [as it was before] and see if that rectifies things ..
Post #237484 27th Jan 2014 5:19pm
coasterburner
Unplugging it did the trick last night . Should I send it back to the ebayer I had it from do you think ? Thanks , Ian .
Post #237486 27th Jan 2014 5:24pm
seems to be the cause doesnt it.....try and get your money back and go for the dvd based mark 4 nav unit...
Post #237488 27th Jan 2014 5:27pm
coasterburner
Thanks very much . Will do .
Post #237491 27th Jan 2014 5:30pm
coasterburner
Looked around and everybody states that the YIB000080 is the upgrade for my car . Have bought one but fittings are completely different . What next ? HELP !!!!
Post #237985 29th Jan 2014 4:00pm
