Home > Maintenance & Mods (L322) > PCV valve - do I need to replace? |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 |
Hey Zeus,
13th Feb 2014 8:08pm |
Zeus Member Since: 18 Dec 2011 Location: Dumfriesshire Posts: 46 |
Hi Asad.
13th Feb 2014 9:24pm |
Squaresausage Member Since: 09 Nov 2013 Location: Hamilton, Lanarkshire Posts: 22 |
Think I will have to do mine, if u look at the crank case bolts there is oil residue leaking out. What has fallen off today:-) |
14th Feb 2014 11:16am |
Hey David,
14th Feb 2014 9:45pm |
The cam cover seals leak due to them going rock hard. I replaced mine when I did the cam cover gaskets. Was very suppressed how hard the seals had become. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
16th Feb 2014 3:48am |
Hi all,
21st Feb 2014 9:34am |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 |
Thanks for this info. I have been humming and hawing whether it's worth doing this job for a while now due to a small leak that I have never been able to place. So these bolt seals you mention -I might consider just replacing these firstly if it's not a big job ?
21st Feb 2014 11:50am |
Hi Shandonman
21st Feb 2014 12:57pm |
