![]() | Home > Maintenance & Mods (L322) > PCV valve - do I need to replace? |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 ![]() ![]() ![]() |
Hey Zeus,
Zeus Member Since: 18 Dec 2011 Location: Dumfriesshire Posts: 46 ![]() ![]() ![]() |
Hi Asad.
Squaresausage Member Since: 09 Nov 2013 Location: Hamilton, Lanarkshire Posts: 22 ![]() ![]() ![]() |
Think I will have to do mine, if u look at the crank case bolts there is oil residue leaking out. What has fallen off today:-) |
Hey David,
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
The cam cover seals leak due to them going rock hard. I replaced mine when I did the cam cover gaskets. Was very suppressed how hard the seals had become. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Hi all,
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
Thanks for this info. I have been humming and hawing whether it's worth doing this job for a while now due to a small leak that I have never been able to place. So these bolt seals you mention -I might consider just replacing these firstly if it's not a big job ?
Hi Shandonman
