Home > Technical (L322) > Drivers side door handle
Harvey123
United Kingdom 2006 Range Rover Autobiography Td6 Java Black
Hi guys.. Need some help..
Just went to open drivers side door and heard a clunk noise from the handle.
The door wouldnt open. So tried it from the inside and works fine. Car locks fine. Just the handle is not latching onto what it should be.
Anyone know whether this is an easy fix or does handle need to be replaced??
Thanks Range Rover Autobiography Black Conversion
Post #237238 26th Jan 2014 12:53pm
the door has two cables , one from the inside handle to the lock mechanism and another from the outside handle to the lock , so your outside cable has gone...
Post #237242 26th Jan 2014 1:29pm
Harvey123
Thanks stan,
Not sure until i open it up but my guess is it may have snapped..
Is this common?? Range Rover Autobiography Black Conversion
Post #237246 26th Jan 2014 1:52pm
seems to be fairly common..there's a few threads re this if you do a search..
Post #237249 26th Jan 2014 2:11pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
This exact problem happened to me tonight. I've searched, but can't see any details on the repair procedure.....can anyone point me in the right direction?
Thanks! 2007 TDV8 Vogue SE Java Black
Post #257503 3rd May 2014 7:25pm
taskam
Managed to bumble through this today. Door card off as shown in PowerfulUK Youtube video (only it was a torqx bolt under the airbag emblem, not a 10mm bolt). The cable had snapped just where it meets the nipple at the door handle, the only tricky bit was getting the orphan nipple out of the catch.
Struggled a bit getting the door card back on until I realised it's easier to remove the black window seal before hooking the door card back on at the top.
Took an hour altogether. 2007 TDV8 Vogue SE Java Black
Post #257935 6th May 2014 5:21pm
