![]() | Home > Technical (L322) > Drivers side door handle |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
the door has two cables , one from the inside handle to the lock mechanism and another from the outside handle to the lock , so your outside cable has gone... |
Harvey123 Member Since: 24 Nov 2012 Location: london Posts: 95 ![]() ![]() ![]() |
Thanks stan,
seems to be fairly common..there's a few threads re this if you do a search.. |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
This exact problem happened to me tonight. I've searched, but can't see any details on the repair procedure.....can anyone point me in the right direction?
Managed to bumble through this today. Door card off as shown in PowerfulUK Youtube video (only it was a torqx bolt under the airbag emblem, not a 10mm bolt). The cable had snapped just where it meets the nipple at the door handle, the only tricky bit was getting the orphan nipple out of the catch.
Struggled a bit getting the door card back on until I realised it's easier to remove the black window seal before hooking the door card back on at the top.
Took an hour altogether. 2007 TDV8 Vogue SE Java Black |
