Home > Wheels & Tyres > Uneven tyre wear |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7834 |
Not had an issue myself, but it'd have a good four wheel alignment check done. Could be upto £60, but will ensure all is correct. They should also highlight any issue and whether it will cause the wear you have.
15th Jan 2014 6:05pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
+1 mjdronfield
15th Jan 2014 6:39pm |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 175 |
Had the same problem, had it checked at full service and they replaced lower link bushes, about £40 each from memory, there's two. Then had full laser alignment. Sorted. |
15th Jan 2014 7:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
As above |
15th Jan 2014 7:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
+1 for alignment.
15th Jan 2014 9:27pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
I had four wheel alignment done 2 weeks ago.
15th Jan 2014 9:59pm |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
Thanks for your replies all
16th Jan 2014 8:45am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Hang on everyone....
16th Jan 2014 8:50am |
Pirelli Scorpion 255/50 on 20" rims as original fit from new |
16th Jan 2014 1:03pm |
There goes my hunch!
16th Jan 2014 3:11pm |
Just make sure you observe what they are doing and go armed with the correct values that they should be aiming for and a full model description for your car.....
16th Jan 2014 5:31pm |
