![]() | Home > Wheels & Tyres > Uneven tyre wear |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Not had an issue myself, but it'd have a good four wheel alignment check done. Could be upto £60, but will ensure all is correct. They should also highlight any issue and whether it will cause the wear you have.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
+1 mjdronfield
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 175 ![]() ![]() ![]() |
Had the same problem, had it checked at full service and they replaced lower link bushes, about £40 each from memory, there's two. Then had full laser alignment. Sorted. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
As above |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
+1 for alignment.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
I had four wheel alignment done 2 weeks ago.
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 ![]() ![]() ![]() |
Thanks for your replies all
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Hang on everyone....
Pirelli Scorpion 255/50 on 20" rims as original fit from new |
There goes my hunch!
Just make sure you observe what they are doing and go armed with the correct values that they should be aiming for and a full model description for your car.....
