Home > Maintenance & Mods (L322) > Apparently battery drain is the amp?!? Best option?
NickH72
Hi all,
According to garage the battery issue I was having is the amp (vse 2008) anyone recommend best action here as new one from LR is 699 plus fitting!! Part number LR039436 could I chance a second hand one from salvage? Or could it be repaired? They say likely a relay not allowing switch off.
The only weird thing to me that remains unanswered is over Xmas I didn't lock the car and the battery seemed fine!? Cannot see how that's connected!? But they said there was a 15amp drain coming from amp intermittently when tested and when unplugged no drain!?
Cheers
Nick
Post #234716 14th Jan 2014 8:48am
i would run the FF with the amp disconnected for a few weeks to see if it actually is the cause...
Post #234720 14th Jan 2014 8:51am
Are they a trusted garage in your opinion Nick? I ask because there will be many more components fed by that feed and unplugging the amp may just take out a link in the chain... Thumbs Up
Post #234723 14th Jan 2014 8:59am
NickH72
Both good points...
The Garage is reputable (can I say who??) in Guildford.
Does my leaving the car unlocked have any baring at all cos I cannot seem to ignore the difference it made.
If I disconnect amp, what will that actually effect?
Also they did say once they disconnected amp they couldn't get it to do it again and were hopeful it might go away!
Cheers
Post #234737 14th Jan 2014 10:26am
the FF has a maze of ecus that 'talk' to each other so the process of disconnecting the amp might have affected another ecu into working properly...just a theory ...
Post #234740 14th Jan 2014 10:35am
NickH72
ok so how an earth do I get to the bottom of it? Sad
Post #234767 14th Jan 2014 12:11pm
I would be wary about what a Main Dealer tells you. To find a specific source of battery drain is very time consuming over a significant period of time. I find it hard to believe a Dealer would spend the necessary time and might just opt for a best guess after a nominal investigation.
The only way to find the drain is to disconnect the -ve cable from the battery, install an ammeter with a scale 0 to 10A between the end of the cable disconnected and the battery -ve terminal and then pull each fuse on the car one by one and after allowing the car to go to sleep each time record the reading on the ammeter.
Most readings with fuses removed should read zero, after the car goes to sleep.
Eventually you will find a fuse or fuses that show a current flow probably in mA that don't go away when the car is asleep.
Record these as with all other fuses.
Once you have checked every fuse you then need to determine what exactly is fed from each of the offending fuses and act accordingly.
If you need an idea of a convenient ammeter set up let me know and I will dig out mine and photograph and post it.
Post #234781 14th Jan 2014 12:45pm
GraemeC
Good advice nicedayforit Thumbs Up
Would you mind posting your ammeter set up photo? I've no need to use one at the moment, but I suspect its something other members will find useful many times..... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #234786 14th Jan 2014 1:19pm
^ I find this convenient for checking battery drain.
The ammeter is a N48CY from Maplins, as below, fitted with a couple of 500mm leads and crocodile clips.
I fit a 10A fuse in the ammeter fuse holder to allow it to operate.
I connect the clips, pass the ammeter out thro the top edge of the bonnet, lay the ammeter on the bottom of the windscreen and close the bonnet.
Then start pulling fuses one by one and recording the results.
http://www.maplin.co.uk/p/400mm-automotive...-max-n48cy
Post #234800 14th Jan 2014 1:56pm
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
Nick
I have just bought an amp off ebay as it was causing similar issues (QXK500105) apparently, I have taken a chance for £30 as my one has a fault not supplying the lower passenger door speakers.
Once I have my original out I am taking it to this place
http://www.cartronics.co.uk/
For them to repair, they may be able to help with your one
HTH
Paul 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #234814 14th Jan 2014 2:36pm
NickH72
Thanks All,
I neither have time nor ability to do this myself sadly...
Paul, Cartronics are 2 mins from one our offices so its in for the day next Weds.. they seem pretty confident on diagnosing the issue before paying for an amp or anything else.
Appreciate all the feedback and ideas and I will keep you posted!
Cheers
Nick
Post #235057 15th Jan 2014 11:17am
Paul_H
Good news Nick, I will probably be over there Saturday with one amp Shocked 2005 Range Rover Vogue with Supercharged Accessories
Post #235128 15th Jan 2014 5:23pm
T24RES
Update Question Ian
Post #241938 11th Feb 2014 1:55pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Cmmon guys you cant leave me in suspense,update please.
Cheers piers
Post #241948 11th Feb 2014 2:32pm
