Home > Maintenance & Mods (L322) > Apparently battery drain is the amp?!? Best option? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35433 |
i would run the FF with the amp disconnected for a few weeks to see if it actually is the cause... |
14th Jan 2014 8:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Are they a trusted garage in your opinion Nick? I ask because there will be many more components fed by that feed and unplugging the amp may just take out a link in the chain... |
14th Jan 2014 8:59am |
NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92 |
Both good points...
14th Jan 2014 10:26am |
the FF has a maze of ecus that 'talk' to each other so the process of disconnecting the amp might have affected another ecu into working properly...just a theory ... |
14th Jan 2014 10:35am |
ok so how an earth do I get to the bottom of it? |
14th Jan 2014 12:11pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
I would be wary about what a Main Dealer tells you. To find a specific source of battery drain is very time consuming over a significant period of time. I find it hard to believe a Dealer would spend the necessary time and might just opt for a best guess after a nominal investigation.
14th Jan 2014 12:45pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Good advice nicedayforit
14th Jan 2014 1:19pm |
^ I find this convenient for checking battery drain.
14th Jan 2014 1:56pm |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
Nick
14th Jan 2014 2:36pm |
Thanks All,
15th Jan 2014 11:17am |
Good news Nick, I will probably be over there Saturday with one amp 2005 Range Rover Vogue with Supercharged Accessories
15th Jan 2014 5:23pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Update Ian |
11th Feb 2014 1:55pm |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
Cmmon guys you cant leave me in suspense,update please.
11th Feb 2014 2:32pm |
