Home > Maintenance & Mods (L322) > Stuck can't open vehicle
Page 1 of 3 123>
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have gone to unlock my RR to drive home and cannot unlock the vehicle using either remote or either key in the drivers door. Is there a way to manually unlock the car or any tips for getting inside.
The red alarm light is flashing on the dash so I guess has some power if the battery is dead.
Any help appreciated. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #234555 13th Jan 2014 6:05pm
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Never happened to me in a ff, but I always thought the key blade would have opened the drivers door Confused
Post #234557 13th Jan 2014 6:10pm
BIGMAMMA
England 2017 Range Rover Autobiography SDV8 Loire Blue
Had to call RAC out with the same thing a few months ago. When he arrived, the damn thing unlocked on the remote as if nothing had happened. Can't help you my friend, but good luck!!
Post #234559 13th Jan 2014 6:12pm
Hi well it sounds like you may have a few problems here, that started most likely from your battery. As to why the door wont unlock from using the key in the drivers door I suspect that you may have a problem with the mechanical linkage that is connected from the key cylinder to the door latch...This could be a problem if your remote doesnt come back online.
You can also try to resync the remote by holding the unlock button and pressing the lock button 3 times, not sure this will work usually done with a key cycle in the ignition so being outside of the vechicle its a bit of a long shot but worth a try.
Worst case senero will be breaking into the vechicle which can be done if you have a few tools and are comfortable taking a few things apart...Otherwise I am afraid a tow to your local dealer will be your only option.
Post #234563 13th Jan 2014 6:20pm
redshovel
This may sound like a joke......but hold the remote to the side of your head while pressing the button.
Worked for me on 5 series once!
Post #234565 13th Jan 2014 6:21pm
rej
Key just turns 90 degrees in either direction no mechanical feel.
AA called, I'm the meantime I will keep trying in case it comes back to life. There is a difference between knowing your sh!t and knowing you're sh!t
Post #234566 13th Jan 2014 6:22pm
redshovel
Mmm... Does sound like mechanical failure Sad .....and expensive Big Cry
Post #234580 13th Jan 2014 7:25pm
Had any Joy with the AA ... Whistle
Mind there is a way to get in the car tho ... Thumbs Up
Post #234582 13th Jan 2014 7:27pm
It's quite possible you have a flat battery even though there is enough voltage left to operate the alarm led.
Do you have a towbar with electrics by any chance?
If you do you could connect another battery to the 12S socket and get sufficient power to operate the locking.
If no towbar electrics you can connect to a side repeater indicator to power things up.
This assumes of course you don't have a faulty key fob(s) as well as a faulty drivers door lock.
Don't suppose you are aware of any local radio transmissions affecting the operation of the central locking?
Has happened to me twice but fortunately the key worked.
If there are any transmissions you locking may just start working again when the transmission ceases.
Post #234586 13th Jan 2014 7:39pm
Rosco
A screwdriver or 2 will get you in Thumbs Up
Post #234588 13th Jan 2014 7:43pm
Failing that go in through the rear number plate Thumbs Up
Post #234591 13th Jan 2014 7:45pm
Are you sure you've not picked up someone else's key ?
Electrical AND mechanical failure is very bad luck
Post #234594 13th Jan 2014 7:46pm
It has been mentioned before that everyone should check that their key actually opens the door manually, just for this very scenario. Holding the key to your head really does increase the range, but it does sound like a flat battery in this case. Previously..
Post #234605 13th Jan 2014 8:15pm
Rosco
Joker is on the same wavelength as I am, rear number plate lights, however not easy when you are in a public place Very Happy
Post #234611 13th Jan 2014 8:23pm
mjdronfield
Have you tried turning the key with the door handle pulled out wards........?
Might not work, but it worked on a 735 I had.
Bit of a long shot I know.......
Do you not have a spare key at home you can fetch ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #234616 13th Jan 2014 8:35pm
Page 1 of 3 123>
