Home > Maintenance & Mods (L322) > Stuck can't open vehicle |
redshovel Member Since: 11 Jun 2010 Location: Belfast Posts: 244 |
Never happened to me in a ff, but I always thought the key blade would have opened the drivers door |
13th Jan 2014 6:10pm |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 174 |
Had to call RAC out with the same thing a few months ago. When he arrived, the damn thing unlocked on the remote as if nothing had happened. Can't help you my friend, but good luck!! |
13th Jan 2014 6:12pm |
Hi well it sounds like you may have a few problems here, that started most likely from your battery. As to why the door wont unlock from using the key in the drivers door I suspect that you may have a problem with the mechanical linkage that is connected from the key cylinder to the door latch...This could be a problem if your remote doesnt come back online.
13th Jan 2014 6:20pm |
This may sound like a joke......but hold the remote to the side of your head while pressing the button.
13th Jan 2014 6:21pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Key just turns 90 degrees in either direction no mechanical feel.
13th Jan 2014 6:22pm |
Mmm... Does sound like mechanical failure .....and expensive |
13th Jan 2014 7:25pm |
Had any Joy with the AA ...
13th Jan 2014 7:27pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
It's quite possible you have a flat battery even though there is enough voltage left to operate the alarm led.
13th Jan 2014 7:39pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
A screwdriver or 2 will get you in |
13th Jan 2014 7:43pm |
Failing that go in through the rear number plate |
13th Jan 2014 7:45pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Are you sure you've not picked up someone else's key ?
13th Jan 2014 7:46pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
It has been mentioned before that everyone should check that their key actually opens the door manually, just for this very scenario. Holding the key to your head really does increase the range, but it does sound like a flat battery in this case. Previously..
13th Jan 2014 8:15pm |
Joker is on the same wavelength as I am, rear number plate lights, however not easy when you are in a public place |
13th Jan 2014 8:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Have you tried turning the key with the door handle pulled out wards........?
13th Jan 2014 8:35pm |
