Home > For Sale & Wanted > Under body guards
nbunney
Under body guards
Anyone got a sump and or tank guard for sale?
Or know who could make me them cheaper then Mantec?
Ta
Post #19530 7th Jun 2010 3:00pm
DMRR
What sort of offroading are you intending to do that requires the sump/tank guard? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #19532 7th Jun 2010 3:26pm
nbunney
Thrasher
Just want to be safe, as I am a member of the NW4x4Response group and yoiu never know where I might have to go.
Post #19540 7th Jun 2010 5:35pm
DMRR
Unless things have changed - you have a few advantages, one being your ability to lift your suspension (and then the vehicle can lift even more if it feels bellied), a kevlar skid plate under the engine and a well designed underbelly - the only thing you might feel a bang on will be the gearbox crossmember and it is plenty tough enough! Unlike the D3 and RRS there is no redundant ladder chassis as well :s
I've done some pretty extreme stuff in a 2004, 2006 and 2010 and never worried about the underside tbh - also bear in mind all that extra weight = less mpg Sad Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #19555 7th Jun 2010 7:23pm
nbunney
No skid plate on mine Big Cry
Post #19557 7th Jun 2010 7:32pm
Fox
Bear in mind that emergency response 4x4 is mostly to get through when the weather is bad.
Such as using roads and tracks where normal cars can't get a doctor through due to snow etc...
I could be wrong, but from what I've seen it's not about hardcore offroading.
I'm sure there are many members with Defenders dying to offroad them for a good cause if the need should ever arise to do the OTT stuff... Smile
Post #19562 7th Jun 2010 8:06pm
nbunney
Fox
As a FULL responder I do know what is involved.
But as the terrain up North is a bit different, to down south I would rather err on the side of caution.
A couple of £100's on a guard and a little less MPG is prefferable to a holed sump
Post #19563 7th Jun 2010 8:18pm
Fox
I think you'll have to bite the bullet and stump up for a Mantec one then.
Because of all the offroad equipment people I've dealt with I've never seen hardly any L322 parts. I don't believe demand is high enough to make them cost effective. Which is probably why Mantec are the only ones as they made them for the G4.
I may be wrong. But I don't think you'll have an alternative unless someone can make you a one-off. But even then a well known tried and tested Mantec one is still preferable.
EDIT:
Checked my catalogue and Terrafirma do one, but it's aslo from Mantec.
Post #19570 7th Jun 2010 9:14pm
nbunney
Cheers for that info Fox Thumbs Up
Post #19573 7th Jun 2010 9:45pm
