Home > Technical (L322) > Big Engine Problem
Page 1 of 5 12345>
FTS999
England 2004 Range Rover Vogue 4.4 V8 Java Black
Big Engine Problem
I had an issue with my 2004 RR Vogue 75,000 miles. It suddenly started to kick out loads of white smoke,
So I did some DIY checks and replaced the MAF and PCV system but it was still happening, so it went to a garage.
They convinced me it was the H/G.
They wouldn't strip down the engine, but the did take it out for me to send away. I sent it to Engine Engineering in Glasgow who did a full strip down and rebuild.
Once the engine was back it was installed only to find it was still missing on number 1 and still pouring white smoke out the back. An auto electrician pin tested the edu and all the wires to the coil packs and said there is nothing wrong with the electrics and all the plugs were sparking fine.
Would I be right in saying it is the injector and the rebuild wasn't required??? Sad
Post #228648 12th Dec 2013 6:23pm
I doubt is was Head Gasket at 75k.....
Post #228649 12th Dec 2013 6:25pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
mine is currently at the indie to look at a similar problem, however not as bad as you describe. at startup there is smoke for a few seconds which then disappear. even when giving it a bit of stick there was no smoke, only when starting it.
I'm holding thumbs that mine is only the oil separator valve (PCV); however indie indicated that it could possibly be the valve stem seals.
still waiting for them to let me know
Post #228659 12th Dec 2013 7:12pm
FTS999
When mine runs there is that much smoke, it looks the SAS have turned up.
Post #228660 12th Dec 2013 7:15pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Turbo?
Post #228663 12th Dec 2013 7:27pm
Definitely turbo. Rolling Eyes
It might even be missing completely?
Post #228664 12th Dec 2013 7:32pm
^ Beat me to it... Previously..
Post #228665 12th Dec 2013 7:35pm
i'm a engine numpty but i didnt think the petrol v8 had a turbo.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #228667 12th Dec 2013 7:38pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
^ Nor did I Confused The forums premier drug dealer and human trafficking consultant
Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III.
Post #228672 12th Dec 2013 7:45pm
johnboyairey
the original poster needs to give more info. petrol? parts changed? engine machined? or checked? fault codes? all we know so far, is its a vogue, and it has at least 1 cylinder... and its cost a lot!!
Post #228674 12th Dec 2013 8:03pm
if you hover your mouse over the OP car profile then you'll see its a v8 4.4..... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #228675 12th Dec 2013 8:04pm
You do realise Kurt was taking the P, yes? Previously..
Post #228676 12th Dec 2013 8:08pm
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
^ Laughing Laughing 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #228677 12th Dec 2013 8:11pm
the 'missing' bit was a clue...my post was for paulb. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #228680 12th Dec 2013 8:16pm
johnboyairey
oooh, my eyes are so bad on pc's I didn't even know that icon was a'car' and you could hover on it! well a bit more info would help us all. if on a diagnostic, at least the emissions would show bad. and to one side... water loss? pressurizing? swapped coil packs to prove? from one side of engine to opposite, on one or all four? easy things to do before pulling the engine....what does the plug look like? were they swapped/changed. if you put an old coloured one in and it comes out cleaner, that's a water problem...
getting my detective hat from the cupboard. and magnifying glass.
Post #228681 12th Dec 2013 8:17pm
Page 1 of 5 12345>
