Home > Technical (L322) > Big Engine Problem |
I doubt is was Head Gasket at 75k..... |
12th Dec 2013 5:25pm |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 |
mine is currently at the indie to look at a similar problem, however not as bad as you describe. at startup there is smoke for a few seconds which then disappear. even when giving it a bit of stick there was no smoke, only when starting it.
12th Dec 2013 6:12pm |
FTS999 Member Since: 18 Jul 2013 Location: Wiltshire Posts: 37 |
When mine runs there is that much smoke, it looks the SAS have turned up. |
12th Dec 2013 6:15pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Turbo? |
12th Dec 2013 6:27pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Definitely turbo.
12th Dec 2013 6:32pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
^ Beat me to it... Previously..
12th Dec 2013 6:35pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i'm a engine numpty but i didnt think the petrol v8 had a turbo.... ... - .- -.
12th Dec 2013 6:38pm |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 |
^ Nor did I The forums premier drug dealer and human trafficking consultant
12th Dec 2013 6:45pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
the original poster needs to give more info. petrol? parts changed? engine machined? or checked? fault codes? all we know so far, is its a vogue, and it has at least 1 cylinder... and its cost a lot!! |
12th Dec 2013 7:03pm |
if you hover your mouse over the OP car profile then you'll see its a v8 4.4..... ... - .- -.
12th Dec 2013 7:04pm |
You do realise Kurt was taking the P, yes? Previously..
12th Dec 2013 7:08pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
^ 2020 Porsche Panamera Turbo Hybrid (V FAST)
12th Dec 2013 7:11pm |
the 'missing' bit was a clue...my post was for paulb. ... - .- -.
12th Dec 2013 7:16pm |
oooh, my eyes are so bad on pc's I didn't even know that icon was a'car' and you could hover on it! well a bit more info would help us all. if on a diagnostic, at least the emissions would show bad. and to one side... water loss? pressurizing? swapped coil packs to prove? from one side of engine to opposite, on one or all four? easy things to do before pulling the engine....what does the plug look like? were they swapped/changed. if you put an old coloured one in and it comes out cleaner, that's a water problem...
12th Dec 2013 7:17pm |
