![]() | Home > In Car Electronics (L322) > Tune2air WMA1000 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8735 ![]() ![]() ![]() |
I'm sure that would be possible, but as all it does is match up your music you have on your local iTunes to the cloud, then you already have it stored on your computer to put onto you phone so is just duplicating you library. There is nothing that can't be fixed with a hammer😜😜
Georgey Member Since: 22 Dec 2016 Location: Cheshire Posts: 5 ![]() ![]() |
Can I ask did you get the 1000 or 3000 model? Ive seen from other forums that the 1000 is the one to have for a RR. Where did you purchase yours from as I've had a good luck on the net and they all seem to be out of stock! Many thanks |
If you have the 2010-> Range Rover then the WMA 1000 is the one to go for, the other has a connector for Audi/ Mercedes built in where as the 1000 just has a 30 pin socket. You will need the lead from the iPod connector in the centre cubby hole as well (not the USB port).
Okay thank you!
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 ![]() ![]() ![]() |
I phone 9, I'm further behind than I thought :unsure: |
If you mean IPhone 7 then yes that's what I use it with. |
Cant even use the excuse that it was late at night when i posted that ![]() |
Hi, Will one of these work the same? https://www.amazon.co.uk/ViseeO-Tune2air-W...B00B52LLJ6 Looks identical, and comes up when you google a Viseoo |
I reckon it should. Not sure that anyone has a Bovee one yet, but the info says it does the same thing. |
Worked perfectly for the first hour.. Now i just get static noises, and even worse, if i switch to radio the static noise keeps going.. and very loudly! Shame |
Sounds like a faulty unit. Get it exchanged see if you fare any better with its replacement!
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 ![]() ![]() |
Apologies for bumping an old thread, but has anyone tried one of these with an android device?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
I'm thinking about this one which is Airplay, not bluetooth:
Don't know, it's about getting screen Control There is nothing that can't be fixed with a hammer😜😜
