Home > In Car Electronics (L322) > Tune2air WMA1000 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8526 |
I'm sure that would be possible, but as all it does is match up your music you have on your local iTunes to the cloud, then you already have it stored on your computer to put onto you phone so is just duplicating you library. There is nothing that can't be fixed with a hammer😜😜
18th Dec 2016 9:37am |
Georgey Member Since: 22 Dec 2016 Location: Cheshire Posts: 5 |
Can I ask did you get the 1000 or 3000 model? Ive seen from other forums that the 1000 is the one to have for a RR. Where did you purchase yours from as I've had a good luck on the net and they all seem to be out of stock! Many thanks |
22nd Dec 2016 11:00pm |
If you have the 2010-> Range Rover then the WMA 1000 is the one to go for, the other has a connector for Audi/ Mercedes built in where as the 1000 just has a 30 pin socket. You will need the lead from the iPod connector in the centre cubby hole as well (not the USB port).
23rd Dec 2016 7:44am |
Okay thank you!
23rd Dec 2016 10:28am |
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 |
I phone 9, I'm further behind than I thought :unsure: |
23rd Dec 2016 10:44am |
If you mean IPhone 7 then yes that's what I use it with. There is nothing that can't be fixed with a hammer😜😜
23rd Dec 2016 5:03pm |
Cant even use the excuse that it was late at night when i posted that |
24th Dec 2016 11:21am |
Hi, Will one of these work the same? https://www.amazon.co.uk/ViseeO-Tune2air-W...B00B52LLJ6 Looks identical, and comes up when you google a Viseoo |
26th Dec 2016 8:14pm |
I reckon it should. Not sure that anyone has a Bovee one yet, but the info says it does the same thing. if you read the reviews i reckon it sounds exactly the same thing and there is a pic of the bovee with tune2air branding on it somewhere on amazon. There is nothing that can't be fixed with a hammer😜😜
26th Dec 2016 8:30pm |
Worked perfectly for the first hour.. Now i just get static noises, and even worse, if i switch to radio the static noise keeps going.. and very loudly! Shame |
30th Dec 2016 4:27pm |
Sounds like a faulty unit. Get it exchanged see if you fare any better with its replacement!
30th Dec 2016 5:21pm |
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 |
Apologies for bumping an old thread, but has anyone tried one of these with an android device?
3rd Apr 2017 3:29pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
I'm thinking about this one which is Airplay, not bluetooth:
17th Apr 2017 11:10pm |
Don't know, it's about getting screen Control There is nothing that can't be fixed with a hammer😜😜
18th Apr 2017 6:11am |
