Home > Maintenance & Mods (L322) > egr blanking kit for td6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
i wonder if this really does give you better performance and mpg..
15th Jul 2011 9:42am |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
Give it a go Stan. Its only 40 quid FFRR TD6 HSE
15th Jul 2011 9:55am |
i'm waiting for someone who 'knows' about egr and if its worth blanking or not...my engine is running very well at the moment and i dont want to upset it.. |
15th Jul 2011 12:15pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i think my brother did something similar on his disco 3 and he said it was much better "RANGEISM WILL NOT BE TOLERATED"
15th Jul 2011 1:10pm |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 |
There's a thread on rrsport about this http://www.rrsport.co.uk/forum/topic18862.html |
15th Jul 2011 1:54pm |
My dad has done it to his TD6 Disco2 and is very pleased with the results. A bit smoother, and 1-2mpg extra. Not loads but worth it. He thought his throttle response was a bit better too. |
15th Jul 2011 1:58pm |
Are they easy to fit?
15th Jul 2011 2:04pm |
cheaper here peeps
15th Jul 2011 2:26pm |
all the advertisers claim improved mpg and performance so it must be true.. |
15th Jul 2011 2:39pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
yes it is a well know fact that these things work, everyone was doing it on the Disco Owners Club, but as stated if you are going to do it i would do a proper job and make sure all the crud that it has fired back into the inlet manifold is cleaned out first. Current: TDV8 (3.6) RRS HSE
15th Jul 2011 5:15pm |
I'll be fitting one next time I'm down at my dads. Will make sure they clean out the inlet manifold as well and will report back on any changes in performance & economy. FFRR TD6 HSE
15th Jul 2011 5:35pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Be worth cleaning out the inter-cooler while you're at it as well. |
15th Jul 2011 5:56pm |
Thanks for advice. I'll add it to the list. Let's hope it all makes a difference. FFRR TD6 HSE
15th Jul 2011 5:59pm |
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 |
Hi everyone, I would say egr are good am going to blank my rangie soon, I have done the egr blanking on my defender td5 I know it's a different vehicle but I had better throttle response and before I done it on defender I was getting 240 miles on full tank whereas now since I done egr I get 290 miles on full tank, best £40 I've spent on my defender which is my daily work horse. Incidentally when my rangie was on diagnostic the other week it showed a egr fault on the computer the same as what happened to defender which prompted me to do egr in first place.
15th Jul 2011 10:20pm |
