Home > Maintenance & Mods (L322) > New LED sidelights
Page 3 of 4 <1234>
the 06-09 headlights come out for bulb changes... ... - .- -.
Post #230707 21st Dec 2013 7:30pm
pld118
After removing the 3 grille screws and taking the front grille off, to remove the headlights, does reading this link help...
http://www.fullfatrr.com/forum/topic22623.html
After removing the headlight unit, unscrew the round plastic cover for the sidelight are and turn bulb holder, remove halogen bulb, replace with LED and replacement is reverse of removal.
Post #230710 21st Dec 2013 7:35pm
td6vogue
Will i have to get the headlight adjust redone then
Post #230724 21st Dec 2013 9:12pm
no, just refit ... ... - .- -.
Post #230726 21st Dec 2013 9:20pm
Andy
Ordered those same led bulbs and fitted them today. Very bright, even I'm daylight! Can't wait to see them tonight!
Bit tight going into the holders though- I thought I was going to break them at one point.
Post #230796 22nd Dec 2013 1:16pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
I did actually unstick one of mine when it was pushed in. I obviously thought Censored but to it's credit I put it back in the correct position and it worked perfectly fine. Still does too and I've been green laning since. Bushy
2003 RR Vogue Monté Carlo Blue
Post #230845 22nd Dec 2013 4:29pm
pld118
Forum member Prop reccommended the HQ autobulb LED sidelights to me and having bought a pair and fitted them I cannot believe how correct and good they look combined with the factory xenon headlights. Thumbs Up
Post #230888 22nd Dec 2013 8:10pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Just search 'car led strip' eBay loads there some are 15 led they can cutdown to any size mine were 12 but cut to 9 now look better
Post #230936 22nd Dec 2013 10:43pm
Andy
As I pulled off the driveway the other day, I noticed my new LED sidelights were flickering in the reflection of my living room window. I wouldn't mind, but the sidelights weren't switched on.
Any ideas?
Post #235323 16th Jan 2014 3:26pm
cold monitoring, perfectly ok..
Post #235334 16th Jan 2014 4:22pm
Bushy513
Yep as Stan said, the car does it's light check when you start up. Normally you wouldn't see that but as LEDs require a lot less voltage than the OEM bulbs they flicker on the test. Panic over lol Bushy
Post #235360 16th Jan 2014 5:41pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
when clicking on the link for the sidelight bulbs and putting my FFRR 2007 details in it says they are not compatible!! which bulbs do I require for a 2007 TDV8 please?? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #235370 16th Jan 2014 6:24pm
Andy
Ah, that's ok then
I did email the seller and he said the bulbs are in the wrong way round Rolling Eyes
Post #235375 16th Jan 2014 6:39pm
pld118
@ Stu -
These will work without errors and are what I fitted based on Prop's learned reccommendation. They are excellent.
Sidelight bulbs. LED @ £9.95/pair (T10 501 W5W Can-Bus LED 10-SMD 5630 bulbs):
http://www.ebay.co.uk/itm/181128879662?ssP...5097208024
Post #235407 16th Jan 2014 9:15pm
Andy
They are the ones I bought.
Post #235503 17th Jan 2014 12:24pm
Page 3 of 4 <1234>
