Home > Maintenance & Mods (L322) > New LED sidelights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
the 06-09 headlights come out for bulb changes... ... - .- -.
21st Dec 2013 7:30pm |
After removing the 3 grille screws and taking the front grille off, to remove the headlights, does reading this link help...
21st Dec 2013 7:35pm |
td6vogue Member Since: 09 Dec 2013 Location: EDN Posts: 27 |
Will i have to get the headlight adjust redone then |
21st Dec 2013 9:12pm |
no, just refit ... ... - .- -.
21st Dec 2013 9:20pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Ordered those same led bulbs and fitted them today. Very bright, even I'm daylight! Can't wait to see them tonight!
22nd Dec 2013 1:16pm |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
I did actually unstick one of mine when it was pushed in. I obviously thought but to it's credit I put it back in the correct position and it worked perfectly fine. Still does too and I've been green laning since. Bushy
22nd Dec 2013 4:29pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Just search 'car led strip' eBay loads there some are 15 led they can cutdown to any size mine were 12 but cut to 9 now look better |
22nd Dec 2013 10:43pm |
As I pulled off the driveway the other day, I noticed my new LED sidelights were flickering in the reflection of my living room window. I wouldn't mind, but the sidelights weren't switched on.
16th Jan 2014 3:26pm |
cold monitoring, perfectly ok.. |
16th Jan 2014 4:22pm |
Yep as Stan said, the car does it's light check when you start up. Normally you wouldn't see that but as LEDs require a lot less voltage than the OEM bulbs they flicker on the test. Panic over lol Bushy
16th Jan 2014 5:41pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
when clicking on the link for the sidelight bulbs and putting my FFRR 2007 details in it says they are not compatible!! which bulbs do I require for a 2007 TDV8 please?? Current: TDV8 (3.6) RRS HSE
16th Jan 2014 6:24pm |
Ah, that's ok then
16th Jan 2014 6:39pm |
@ Stu -
16th Jan 2014 9:15pm |
They are the ones I bought. |
17th Jan 2014 12:24pm |
