![]() | Home > Maintenance & Mods (L322) > New LED sidelights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
the 06-09 headlights come out for bulb changes... ... - .- -.
After removing the 3 grille screws and taking the front grille off, to remove the headlights, does reading this link help...
td6vogue Member Since: 09 Dec 2013 Location: EDN Posts: 27 ![]() ![]() |
Will i have to get the headlight adjust redone then |
no, just refit ... ... - .- -.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Ordered those same led bulbs and fitted them today. Very bright, even I'm daylight! Can't wait to see them tonight!
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
I did actually unstick one of mine when it was pushed in. I obviously thought |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Just search 'car led strip' eBay loads there some are 15 led they can cutdown to any size mine were 12 but cut to 9 now look better |
As I pulled off the driveway the other day, I noticed my new LED sidelights were flickering in the reflection of my living room window. I wouldn't mind, but the sidelights weren't switched on.
cold monitoring, perfectly ok.. |
Yep as Stan said, the car does it's light check when you start up. Normally you wouldn't see that but as LEDs require a lot less voltage than the OEM bulbs they flicker on the test. Panic over lol Bushy
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
when clicking on the link for the sidelight bulbs and putting my FFRR 2007 details in it says they are not compatible!! which bulbs do I require for a 2007 TDV8 please?? Current: TDV8 (3.6) RRS HSE
Ah, that's ok then
@ Stu -
They are the ones I bought. |
