![]() | Home > Technical (L322) > Groan.... its starting to do my head in .( |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Do the lights go out when you turn the steering wheel full lock to full lock but then come back on again later? Previously..
Needle Member Since: 07 Dec 2012 Location: Aberdeen Posts: 51 ![]() ![]() |
nope they stay on |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Take it up to Greenbank 4x4 mate. I use them for anything I can't fix and they're top notch. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I'd guess its a reluctor ring on one of the driveshafts that's not sending a signal to one of the wheel speed sensors. Car thinks the other 3 wheels are spinning so activates abs. It then realises the readings are not right, so disables abs, dsc, etc
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
Look for gunge on the connectors in the ABS module. This is the first item on the canbus loop and when it throws a fault it also stops the info flow and triggers the HDC and other sensors. I had this once with all the lights on imaginable and cleaned a small spec of greeny corrosion off one connector in the ABS module and all good (see my gallery for pics) |
