Home > Maintenance & Mods (L322) > Activating FBH in Testbook
Andy
Does anyone know where the option to activate the FBH is in Testbook? Took the car to my local Indy yesterday and we couldn't find it anywhere in any of the sections. I made a call to the Land Rover dealers in Birmingham and they didn't know either.
If anyone knows, I'd be grateful
Post #225469 27th Nov 2013 7:26am
Andy
Ok then.... Does anyone know a dealer that's done this?
Post #225603 27th Nov 2013 5:58pm
there's ref in this thread that someone was getting it done at a dealer,
http://www.fullfatrr.com/forum/post211383.html ... - .- -.
Post #225610 27th Nov 2013 6:26pm
i'd invest in an iidtool Andy and do it yourself.. ... - .- -.
Post #225611 27th Nov 2013 6:27pm
Andy
I don't fancy spending £290 just to activate FBH!
Post #225664 27th Nov 2013 10:17pm
but how much will a dealer/garage charge you to do that job......
its an investment cos it will clear faults especially he dreaded suspension ones, and you can do other stuff with it as well..have a look on the GAP site ,enter your year and use the drop down menus to see all the functions..
http://www.gap-diagnostic.com/products/iidtool.html ... - .- -.
Post #225692 28th Nov 2013 8:40am
Andy
I have RSW for (nearly) everything else
Post #225698 28th Nov 2013 9:12am
doesnt storeys recent update switch on the fbh ? .. ... - .- -.
Post #225701 28th Nov 2013 9:27am
Andy
Not that I can see, no. Probably because of the lack of diesels in the USA
Post #225730 28th Nov 2013 1:06pm
that makes sense...good luck on your quest .. Thumbs Up ... - .- -.
Post #225731 28th Nov 2013 1:12pm
Ideally you want to get some with a Faultmate as it will be easier to enable with that or an autologic, a lot of indies have these so could be worth asking one. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #225797 28th Nov 2013 8:44pm
Andy
I've called 3 dealers and 2 indys. None of them know how to do it !
I've lived without one for 4 years- might as well call it a day.
Post #226092 30th Nov 2013 8:37am
i'm convinced that you do use more diesel [less mpg] when the fbh is in use so its not such a bad thing not having it noddy.. ... - .- -.
Post #226100 30th Nov 2013 9:58am
I'm convinced the other way as it warms the engine up so much quicker, even better if used before hand as they don't burn much fuel when in use.
Maybe a trip to Craig would be a better use of your time and build it into a day trip to take the mrs away Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #226336 1st Dec 2013 12:49pm
SteveMFr
Site Sponsor
Nope Stan, Kingpleb is absolutely correct.
A diesel motor is a huge, inefficient pump before it warms up. The little FBH runs at max efficiency nearly instantly and actually uses less fuel and reduces emissions vs. a cold start. Webasto has literature on this somewhere...
Noddy, if I were in your vicinity I'd come over and put these threads out of their misery Wink
We are getting ready to make some big announcements regarding our products. Hold on a little longer - and if you do not make the leap then, well... then you deserve to freeze. Wink Wink Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #226361 1st Dec 2013 4:11pm
