Home > Maintenance & Mods (L322) > Activating FBH in Testbook |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Does anyone know where the option to activate the FBH is in Testbook? Took the car to my local Indy yesterday and we couldn't find it anywhere in any of the sections. I made a call to the Land Rover dealers in Birmingham and they didn't know either.
27th Nov 2013 7:26am |
Ok then.... Does anyone know a dealer that's done this? |
27th Nov 2013 5:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35415 |
there's ref in this thread that someone was getting it done at a dealer,
27th Nov 2013 6:26pm |
i'd invest in an iidtool Andy and do it yourself.. ... - .- -.
27th Nov 2013 6:27pm |
I don't fancy spending £290 just to activate FBH! |
27th Nov 2013 10:17pm |
but how much will a dealer/garage charge you to do that job......
28th Nov 2013 8:40am |
I have RSW for (nearly) everything else |
28th Nov 2013 9:12am |
doesnt storeys recent update switch on the fbh ? .. ... - .- -.
28th Nov 2013 9:27am |
Not that I can see, no. Probably because of the lack of diesels in the USA |
28th Nov 2013 1:06pm |
that makes sense...good luck on your quest .. ... - .- -.
28th Nov 2013 1:12pm |
Ideally you want to get some with a Faultmate as it will be easier to enable with that or an autologic, a lot of indies have these so could be worth asking one. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Nov 2013 8:44pm |
I've called 3 dealers and 2 indys. None of them know how to do it !
30th Nov 2013 8:37am |
i'm convinced that you do use more diesel [less mpg] when the fbh is in use so its not such a bad thing not having it noddy.. ... - .- -.
30th Nov 2013 9:58am |
I'm convinced the other way as it warms the engine up so much quicker, even better if used before hand as they don't burn much fuel when in use.
1st Dec 2013 12:49pm |
Nope Stan, Kingpleb is absolutely correct. A diesel motor is a huge, inefficient pump before it warms up. The little FBH runs at max efficiency nearly instantly and actually uses less fuel and reduces emissions vs. a cold start. Webasto has literature on this somewhere... Noddy, if I were in your vicinity I'd come over and put these threads out of their misery We are getting ready to make some big announcements regarding our products. Hold on a little longer - and if you do not make the leap then, well... then you deserve to freeze. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
1st Dec 2013 4:11pm |
