Home > Technical (L322) > TD6 starting problem
Needle
2003 Range Rover SE Td6 Java Black
I had the same problem too... faulty injector .)
Post #227308 6th Dec 2013 8:01am
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Thanks for that Needle, it well could be an injector,but its not showing up any faults on my Hawkeye.
Post #227326 6th Dec 2013 12:14pm
If it doesn't get better with the cleaner then do a leak off test and you'll know.
Post #227335 6th Dec 2013 2:29pm
piersie
Kurt without appearing to be dimmer then i am already, what is a leak off test. Embarassed Embarassed
Post #227354 6th Dec 2013 5:10pm
