![]() | Home > Technical (L322) > TD6 starting problem |
Needle Member Since: 07 Dec 2012 Location: Aberdeen Posts: 51 ![]() ![]() |
I had the same problem too... faulty injector .) |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 ![]() ![]() ![]() |
Thanks for that Needle, it well could be an injector,but its not showing up any faults on my Hawkeye. |
If it doesn't get better with the cleaner then do a leak off test and you'll know. |
Kurt without appearing to be dimmer then i am already, what is a leak off test. |
