Help Needed with weird noise | |
Hi Forum members, I need some help with to identify the source of a whinning "noise" coming from my RR at 70 mph. AT 65 mph and under full throttle there is no noise so am discounting anything from the engine. It may be something loose due to windage but I'm dammed if I can see anything. It appears to come from underneath the dashboard. It's hard to describe but the only thing I've heard like it was when the windscreen seal lifted up and it was vibrating. I have obvioulsy checked that and it's not that this time.
Also thought wheel or drive shaft bearing but as it only appears at 70mph and above and no change going round corners don't think its them.
Have any of you heard that noise behind the dash when you turn off the ignition, it's like a pump noise and goes off after about 1 minute.
Any ideas ?
D16XEY
