Home > Technical (L322) > Help Needed with weird noise |
Elduke Member Since: 21 Apr 2013 Location: Glasgow Posts: 148 |
Ive got a similar noise going on when I hit about 70 but its more of a I think its probably the pollen filter housing that's not properly seated as it only started after I had it off to change a couple of pcv valve hoses. Just left it as it will need to come back out at some point again and get by with turning up the radio Only a couple of nuts to undo so no excuse really!
11th Nov 2013 10:11pm |
D16XEY Member Since: 29 Oct 2013 Location: Broughty Ferry Posts: 20 |
Thanks Elduke,
12th Nov 2013 12:33pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3137 |
I had a noise on my previous TD6 which was the same as yours. It was the rubber at the front of the rain gutter on the driver's side (just above the windscreen) which was lifting up and causing turbulence. Put back in, secured down and back to normal running. |
12th Nov 2013 12:42pm |
Hi Dolphinboy,
12th Nov 2013 9:03pm |
