Home > Maintenance & Mods (L322) > Brake squeak and warm alloy
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Driving home yesterday and heard a intermittent long squeal / squeak but it went as soon as i braked but occasionally come back. Once I arrived home I had a quick look around and noticed that the rear passenger alloy was warm along with the brake disk etc.
Does this mean I need a new caliper as the caliper is sticking and causing friction? 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #220655 4th Nov 2013 12:15pm
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Hi Sounds like it...
I have had the same issue... Don't leave it too long...
I had to have a new disk - new pads and then finally a new calliper...
All mine covered under warranty has I mentioned an issue at buying it and they didn't identify it as brakes...
Trev Current Cars
(Sold) Range Rover TD6 05 Vogue SE - 85k - Zambezi Silver - Black Leather..
Kia Ceed (4) 1.6 - 33k - Silver
Previous.
VW Golf 2008 2.0 SDI (With Add Ons) - 109k Silver
Vauxhall Zafira 2.2 Petrol SRI - with Ex Pack 32k -Turquoise (traded for the FFRR)
Post #220662 4th Nov 2013 12:30pm
could be worn pads... ... - .- -.
Post #220664 4th Nov 2013 12:34pm
supershuttle
I needed a caliper, new disc and pad. Geoff
Post #220666 4th Nov 2013 12:39pm
Budgie
I was another who ended up replacing the calliper, although you could try removing the pads and working the piston in & out a few times to see if that will do anything.
I tried that on mine and it didn't work so I replaced the thing.
As said above, don't leave it too long as the heat created could also effect your wheel bearing and that even more money to spend. Wink
Post #220673 4th Nov 2013 12:54pm
wedgel322
Thanks for the info. I will get it booked in for the indy to have a look. It had new pads and disks about a year ago. Will have a scout around for a price on the caliper Sad 2003 Range Rover HSE 3.0 TD6
Post #220679 4th Nov 2013 1:35pm
It could be as simple as the ends of the pads rusted and jammed in the caliper, so they do not release. I am sure all shall be revealed when you get the wheel off and have a closer look. Thumbs Up Previously..
Post #220717 4th Nov 2013 5:20pm
Same problem I had the other week , thought I was going to need a new caliper left it at the local garage they cleaned and greased up what was needed ...... £48 later sorted Thumbs Up ====================================
Post #220723 4th Nov 2013 5:39pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
caliper seal kit to overhaul the caliper are only £10-£20 did all 4 calipers last year after the fronts stuck on.
Post #221263 6th Nov 2013 8:24pm
