Home > Maintenance & Mods (L322) > Brake squeak and warm alloy |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 |
Driving home yesterday and heard a intermittent long squeal / squeak but it went as soon as i braked but occasionally come back. Once I arrived home I had a quick look around and noticed that the rear passenger alloy was warm along with the brake disk etc.
4th Nov 2013 12:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
could be worn pads... ... - .- -.
4th Nov 2013 12:34pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I needed a caliper, new disc and pad. Geoff |
4th Nov 2013 12:39pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I was another who ended up replacing the calliper, although you could try removing the pads and working the piston in & out a few times to see if that will do anything.
4th Nov 2013 12:54pm |
Thanks for the info. I will get it booked in for the indy to have a look. It had new pads and disks about a year ago. Will have a scout around for a price on the caliper 2003 Range Rover HSE 3.0 TD6
4th Nov 2013 1:35pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
It could be as simple as the ends of the pads rusted and jammed in the caliper, so they do not release. I am sure all shall be revealed when you get the wheel off and have a closer look. Previously..
4th Nov 2013 5:20pm |
Same problem I had the other week , thought I was going to need a new caliper left it at the local garage they cleaned and greased up what was needed ...... £48 later sorted ====================================
4th Nov 2013 5:39pm |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
caliper seal kit to overhaul the caliper are only £10-£20 did all 4 calipers last year after the fronts stuck on. |
6th Nov 2013 8:24pm |
