![]() | Home > Technical (L322) > can anyone help please. message centre problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
looks french..can you change your language to english. ... - .- -.
Jackofq300 Member Since: 11 Aug 2013 Location: Dart ford Posts: 45 ![]() ![]() ![]() |
hi stan. yeah i was thinking that. ive a diagnostic tool and seems to work fine and shows no faults. the car is uk spec. any idea to change language. regard. jacko. |
should be in the menu somewhere..you havnt put a new nav disc in by any chance.. ... - .- -.
ok thanks i will check. it does have the upgrade tv plus 2010 satnav. the cars very new to me. |
there are issues with aftermarket sat nav discs with speed cams on them cause the language to be defaulted to french..
could of hit the nail right on the head there. my wife has been mucking around with the head unit. i wil check it out. thank you. top man stan.. |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Is it French or Portuguese?
hopefully if Paul can default the language to english then the error will become more clearer.. ... - .- -.
thanks again chaps but i dont think it would be the lights as they are the 2010 led type. i tryed to change language lastnight but had no luck. not having a manual for the head unit doesnt help either. i will keep trying |
oh stan i dont think you posted that thread. i could not see it on your reply |
great thank you lads. when i turn the camera alert on it changes back to english. and says "check front side light" but the lights are fine. ive got a 2010 front convertion so the lights are led and working fine. ive had the car about 3 months now and this problem only ocurred a couple of days ago. any ideas how to fix this little bug peeps?? the diagnostic tool does not switch it off worst luck. |
probably one of the bulbs are now causing a canbus error..
