![]() | Home > Technical (L322) > Juddering noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
when on LPG or petrol? ... - .- -.
Wallace Torrens Member Since: 19 Feb 2012 Location: Coleraine Posts: 6 ![]() ![]() ![]() |
On LPG Stan it is if the car is in to high of a gear for example when exiting a roundabout. Does not happen at higher speeds and does not happen all the time. But when I drive using the manual gears it's ok. |
if its ok on petrol then you have identified the problem...an authorised LPG garage is your best bet.. ... - .- -.
I will try that Stan. I was worried that it might be a gearbox problem. |
