Home > Technical (L322) > Juddering noise
Wallace Torrens
Northern Ireland 2003 Range Rover Vogue 4.4 V8 Java Black
Juddering noise
Hi everyone I drive an 03 4.4 vogue which is converted to LPG. I have noticed a shuddering at low speed. It happens mostly when I'm travelling at approx. 30 mph accelerating to a higher speed. It does not happen all the time. The noise appears to be coming from the front passenger side. If I select manual gear changing this does not happen. Any ideas anyone. Also I've noticed when I put my foot on the brake pedal their is a clicking noise. Any information would be greatly appreciated.
Post #219605 29th Oct 2013 10:01pm
when on LPG or petrol? ... - .- -.
Post #219645 30th Oct 2013 7:44am
Wallace Torrens
On LPG Stan it is if the car is in to high of a gear for example when exiting a roundabout. Does not happen at higher speeds and does not happen all the time. But when I drive using the manual gears it's ok.
Post #219678 30th Oct 2013 9:27am
if its ok on petrol then you have identified the problem...an authorised LPG garage is your best bet.. ... - .- -.
Post #219681 30th Oct 2013 9:29am
Wallace Torrens
I will try that Stan. I was worried that it might be a gearbox problem.
Post #219684 30th Oct 2013 9:38am
