Home > Maintenance & Mods (L322) > Brake Disc Change
Page 5 of 5 <12345
dantheman
Fair one Joe: a perfectly well crafted tool.
Just watch you don't get thrown in the tower... Whistle
Mind you, if like the A Team they have an old metal bathtub, some sheet steel, a trolley and oxy-acetylene where they lock you up:
or even:
Post #21694 6th Jul 2010 10:32pm
Big Cry .
Post #21695 6th Jul 2010 11:20pm
dan_uk_1984
I had the rear discs and pads changed today, £50, not bad. Now Vented, drilled & groved front and rear.
Post #26399 25th Aug 2010 7:18pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
I did my front discs on Monday evening and rear discs last night. Took about 45mins per side, from start to finish. Fairly straight forward. If you do it, make sure you have new wear sensors as they seem to have a habit of breaking when they are coming out. Sad
Post #26410 25th Aug 2010 10:10pm
was this in a garage or did you do this yourself...btw where did you get the bits dan? ... - .- -.
Post #26425 26th Aug 2010 9:31am
still very interested in your very competitive cost for the pads/discs dan ... - .- -.
Post #27549 9th Sep 2010 8:49am
dan_uk_1984
Soz fella, didn't see your post there.
I paid £50 in labour for the front (this also included labour to fit a CV Boot) and then I paid £50 for the back a few weeks later BUT this included the handbrake shoes on the back.
I got the parts from Island4x4: http://www.island-4x4.co.uk/-c-144_145.html and I went for the Drilled & Grooved discs and so far have been very happy with them. The whole order came to £150 with free P&P and the discs look great through the 20" alloys!
This guy is an absolute star, I always pay him cash. Usually I leave the car with him the night before as he’s only down the road and pick it up after work the following day. He doesn’t have a courtesy car which is the only problem, but I just get the o/h to give me a lift.
1 x Front Brake Disc Drilled & Grooved (2) L322 02-05 DA4609 £59.99
1 x Rear Brake Pad Set Range Rover L322 02-05 SFP000120 £16.99
1 x Rear Brake Disc Drilled & Grooved (2) L322 02-05 DA4610 £48.99
1 x Front Brake Pad Set (Mintex) Range Rover L322 02-05 SFC500050 M £24.99
Post #27560 9th Sep 2010 9:41am
cheers dan, i was silly in thinking you paid £50 for all the bits and fitting on the fronts...i have so much to learn about the 'not so' cheap costs that the FFRR ensues... ... - .- -.
Post #27566 9th Sep 2010 10:01am
dan_uk_1984
I doubt there are many cars you can do a complete brake change for £150, and labour is labour... As long as you stay away from the dealerships!
Post #27578 9th Sep 2010 10:24am
i have an advantage where my eldest is a qualified mechanic and still lives at home ...tech on tap ... ... - .- -.
Post #27580 9th Sep 2010 10:34am
dan_uk_1984
To be fair I was all up for doing the discs myself, but couldn't get the Censored off! I'll try and do the next lot... I still want to bleed the brakes, will prolly do that this weekend weather permitting.
Post #27584 9th Sep 2010 10:44am
Just some pics of my discs after about 1000 miles. (This was with new pads too) Still impressive stopping power.
Post #27840 11th Sep 2010 12:05pm
marques.a
Brazil
Sorry to resurrect this topic! In search of releasing my clinging disk, I arrived at this topic.
I managed to loosen mine by inserting a screw, a washer and a nut in the tweezer support and I was squeezing from behind until the disc came loose. It worked for me, the only problem is that it dents the disk protection a little, but nothing that pliers can't fix. Thumbs Up
Hugs,
Post #597937 18th Jun 2021 5:03pm
Page 5 of 5 <12345
