Home > General > looking at a high miler TDV8
barrieeld
Any major things
Should I get the gearbox oil flushed?
Suspension air bags suspect at higher mileage or just your luck?
Anything else i need to be made aware of? Range Rover SC 35th Anniversary 2006
Post #215815 11th Oct 2013 8:54am
How high a mileage?
I asked my Indy about flushing the gearbox and his response was, "if it ain't broke...........!"
I guess the suspension depends on the type of terrain it's been used on. Got - 2017 SDV8 Autobiography in Loire Blue
Post #215826 11th Oct 2013 10:13am
Alan, id'e question your indie's response my friend... Once the damage has been done "there aint no fixing it" replace it with a very big bill! Or service/flush it and prolong its life! No brainer!!!
Bad advise id'e say! Rolling Eyes
Post #215831 11th Oct 2013 10:53am
Prop
Would definitely agree with what Craig says.
The "if it aint broke" approach would mean you would never give your engine oil a change, as the oil is not broken, its just slowly degrading and giving less protection. So would definitely recommend an oil change for the transmission. After all Craig has done a great many and I am sure he gets to see exactly what the oil comes out like.
The flush bit is another thing all together, will leave the experts to comment on this one.
Post #215834 11th Oct 2013 11:25am
I don't think you're comparing like for like. The gearbox is "supposed" to be sealed for life, whereas the engine isn't......
I'm more than happy to have it done (including the flush) if someone can tell me it's the right thing to do. Got - 2017 SDV8 Autobiography in Loire Blue
Post #215838 11th Oct 2013 12:09pm
Prop
It's the right thing to do. Smile
Post #215840 11th Oct 2013 12:23pm
Prop
Sorry forgot to mention, not sure about the flush though, as there are different degrees of flush.
Post #215841 11th Oct 2013 12:26pm
barrieeld
car I'm looking at has done 125k miles.
4 previous owners.
been looked after by LR then last 3 years specialist independent
Thanks. Range Rover SC 35th Anniversary 2006
Post #215847 11th Oct 2013 12:35pm
Prop
Barrieeld, this link is always a good starting point to read/print out before viewing.
http://www.fullfatrr.com/forum/post189410.html#189410
Post #215868 11th Oct 2013 3:01pm
Sealed for life... Just like the 5 speed was in the TD6 Whistle
Your choice Alan... Advise given Whistle
Post #215902 11th Oct 2013 4:31pm
I didn't say I wasn't listening Craig! Just thought that comparison between the engine oil change and gear box oil change was a bit spurious! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #215909 11th Oct 2013 4:51pm
Prop
Perhaps not the best choice for comparison agreed. But my point was that just because its not broke doesn't mean it wont break. And just because LR states the gearbox is sealed for life doesn't mean an oil change will not benefit the gearbox as after 70k miles or so I am pretty sure the gearbox oil is not as effective at protection as it was when new.
Post #215919 11th Oct 2013 5:21pm
Tdv8 gearbox is not sealed for life and im pretty sure land rover now recommend an oil and filter change at 100k or 10 years.
It really does depend on what it has been put through. If it has regularly towed then it would need doing earlier. IMHO. There is nothing that can't be fixed with a hammer😜😜
Post #215932 11th Oct 2013 6:18pm
pld118
In the last month, I went for a test drive in our SC with a Master Technician from Stratstone Bury.
Amongst things the car had been in for was a leak from the gearbox sump/ need for a new gasket was the cause. On his advice, the garage removed the existing oil, replaced the filter, put new oil in, replaced the actual sump cover, new gasket and sealed the unit back up. He told me that this process would have been due on this car at 100,000 miles and is effectively a gearbox service. He said the process and having driven the car before and after allowed him to be satisfied that there were no gearbox problems and none within the unit (I.e no signs of glitter/metal shavings noted during the 'service'). He seemed pleased that he had done this and said it was a very early preventative process as the car is nowhere near 100k miles. He didn't mention a flush having been done though. I've read conflicting views re pros and cons of a flush but obviously I'm the type of owner who is guided by the professional and I'm happy that what was originally to be a new gasket, ended up having a fuller job done Thumbs Up
Post #215934 11th Oct 2013 6:43pm
did the gearbox perform better after the oil change? ... - .- -.
Post #215936 11th Oct 2013 6:45pm
