Home > Maintenance & Mods (L322) > changing wather pump fbh
Wheel off, arch liner out, should be easier then.
It's so much easier to work on in a disco!! It's in the engine bay on top of the inner wing, super easy. There is nothing that can't be fixed with a hammer😜😜
Post #289608 29th Oct 2014 7:10pm
miggit
To bleed the system when refilling you will find bleed valves on the header tank, next to the filler cap. On the EGR valve under the the front engine cover (front of engine, held on with 2 hex screws and has the power steering filler cap pointing through), and there is a last one on the coolant rail. This one I can not remember where it is, I think it is on the right hand side of engine, standing in front of car looking at engine, near the top of the cover behind the power steering pump. All I know is I only found this after I had filled the system and bled all the air using the other two! And then its the waiting game, as the engine heats up the air bubbles up in the header tank, you fill it and it bubbles some more. Eventually when the engine is up to normal temp, the bubbles should stop. Fill it up and refit the cap, I normally let it run for another 15 minutes, then let it cool down. When it's cold, preferably the next morning, check that the levels are OK Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #289625 29th Oct 2014 7:55pm
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
Thx. Any tips about what the switch is for. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #289643 29th Oct 2014 8:37pm
It's called a plug in English, you will find spare ones all over the car, they use one wiring loom for all models and for all options so it will be for something your car doesn't have, so don't worry about it..... Thumbs Up Pete
Post #289648 29th Oct 2014 8:54pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
i had a right game bleeding the air out of the fbh,i had to bleed air out of the fbh water pump first(with the fbh and pump running, but it gets very hot very quick with no water circulating) then top the rest of the cooling system up after,took a few attempts but removed the hose where it goes through the inner wing to bleed the pump as thy are not self priming
best of luck nige
Post #289663 29th Oct 2014 9:53pm
Norway
Got the job done. But it did take some time. I hade to go both thrue the inner arch liner and in under the battery to get all the hoses off. Now whats left is to delete the fault codes.
Very Happy -03V td6
Post #289841 30th Oct 2014 7:49pm
Norway
Hey guys. The engine wont stay heated at high rpms nor when its below -5 degrees Celcius. Iw delited The old error codes responding to The defect waterpump. Any ideas what to look at next is appreciated. Any merry christmas to you all. -03V td6
Post #300725 24th Dec 2014 9:42am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi there,
I had similar trouble earlier this year when my main and EGR thermostats failed. Temperature would be slow to rise then would cool quickly at high speeds. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #300901 25th Dec 2014 9:42pm
