![]() | Home > Wheels & Tyres > Bottle Jacks |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Words taken out of my mouth |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
have gone for one of these
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 965 ![]() ![]() ![]() |
chaps, where can i get one of these mini / bmw adapter's and do they fit all L322's?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
ebay Andy, links are in previous posts.. ... - .- -.
Just tap out the spring clip in the hole in the side of the top blue cradle on the end of the shaft.
Thanks very much... Think I understand all that |
or the extra money you get a bottle jack with a flat top, use the adaptor as required, and then you can use the bottle jack for other purposes as well...... |
But if you fit the adapter with a removable pin and keep the head you removed from the jack in the first place you can refit it at will to use elsewhere. |
Where to buy a removable pin please? |
Piece of stainless steel rod of suitable dia, 4mm will suffice, bend one end into a finger loop, cut to length and voila, removable pin. |
nightster1 Member Since: 26 Feb 2012 Location: Cork Posts: 14 ![]() ![]() ![]() |
Yes, just rec'd delivery of one of these. It works a treat. Original flimsy scissors jack is just too dangerous and liable to distort and collapse when extended unless you are on solid level ground with wheel chocks firmly in place Current:- TD6 HSE Past:- Jeep Grand Cherokee Limited CRD x2 Jeep Cherokee Limited TD x1 |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I bought a simple bottle jack with a small round disc on the top and drilled out a circular recess (approx 25mm in diameter) from the base of the aluminium Mini/BMW adaptor so that the disc on the top of the jack sits fits in the recess. If I was really keen, I could drill a hole for a grub screw with a wing nut on it, but does not seem necessary.
Original Sprinter pin knocked out easily with a small Allen key and a hammer leaving the jack shaft looking as per the below picture (apols if picture upside down/ iPad).
