Home > Wheels & Tyres > Bottle Jacks
Page 3 of 4 <1234>
Martin
Site Admin
Words taken out of my mouth Wink
Post #208321 5th Sep 2013 5:05pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
have gone for one of these
http://www.amazon.co.uk/Draper-04983-Tonne...ottle+jack
also have the BMW / mini adaptor for the jacking point
Post #208810 8th Sep 2013 9:28am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
chaps, where can i get one of these mini / bmw adapter's and do they fit all L322's?
andy
Post #209298 10th Sep 2013 12:07pm
ebay Andy, links are in previous posts.. ... - .- -.
Post #209299 10th Sep 2013 12:09pm
pld118
Hi,
Can anyone please advise/ spell out how exactly the top comes of this sprinter bottle jack and how you get the base of the BMW adapter to fair onto the sprinter jack (I've read that someone used a punch to remove the top of the jack and then drilled the adapter to sit on top but want to be sure before I start bashing hacking and making mess?
Confused as I've just punched the jack and all that happened was I nearly broke my knuckles/ skin's come right off!
Please/ thanks...
Post #209488 11th Sep 2013 10:07am
Just tap out the spring clip in the hole in the side of the top blue cradle on the end of the shaft.
You are then left with a 16mm dia top section of jack shaft some 16mm long.
The bmw adapter needs a hole 16mm dia drilled centrally in the bottom of the circular base 16mm deep.
It then fits on the top of the jack shaft.
You then have the choice of leaving the jack adapter loose, drilling the side of the adapter to fit a spring clip or drilling the side of the adapter and fitting an "R" clip.
If you do decide to leave the adapter loose whatever you do do not compress the jack shaft fully into the jack.
Post #209494 11th Sep 2013 10:31am
pld118
Thanks very much... Think I understand all that Thumbs Up
Post #209542 11th Sep 2013 1:20pm
Rambles
or the extra money you get a bottle jack with a flat top, use the adaptor as required, and then you can use the bottle jack for other purposes as well......
Post #209889 12th Sep 2013 7:11pm
But if you fit the adapter with a removable pin and keep the head you removed from the jack in the first place you can refit it at will to use elsewhere. Thumbs Up
Post #209900 12th Sep 2013 7:46pm
pld118
Where to buy a removable pin please?
Post #209902 12th Sep 2013 7:53pm
Piece of stainless steel rod of suitable dia, 4mm will suffice, bend one end into a finger loop, cut to length and voila, removable pin. Thumbs Up
http://www.ebay.co.uk/itm/304-Stainless-St...4171cde3d4
Post #209905 12th Sep 2013 8:00pm
pld118
Post #209908 12th Sep 2013 8:28pm
nightster1
Ireland 2004 Range Rover HSE Td6 Epsom Green
SoggyBottoms wrote:
http://www.ebay.co.uk/itm/2-5-TON-HYDRAULIK-BOTTLE-JACKS-BRAND-NEW-OFF-MERC-SPRINTER-VANS-100-IN-STOCK-/261145375799?pt=UK_Lifting_Moving_Equipment&hash=item3ccd7a3437
pretty sure this is the one I bought
Yes, just rec'd delivery of one of these. It works a treat. Original flimsy scissors jack is just too dangerous and liable to distort and collapse when extended unless you are on solid level ground with wheel chocks firmly in place Current:- TD6 HSE
Past:- Jeep Grand Cherokee Limited CRD x2
Jeep Cherokee Limited TD x1
Post #209919 12th Sep 2013 9:18pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I bought a simple bottle jack with a small round disc on the top and drilled out a circular recess (approx 25mm in diameter) from the base of the aluminium Mini/BMW adaptor so that the disc on the top of the jack sits fits in the recess. If I was really keen, I could drill a hole for a grub screw with a wing nut on it, but does not seem necessary.
I chose a Sealey Yankee 4tonne jack as it met a range of needs and the adaptor I bought from eBay for about £7 plus p&p.
It would never have occurred to me to do this if it had not been for the forum which pointed out that the stock jack is. It suitable and that the adaptors were readily available: as ever, very grateful to forum members for their ingenuity. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #209947 13th Sep 2013 7:16am
pld118
Original Sprinter pin knocked out easily with a small Allen key and a hammer leaving the jack shaft looking as per the below picture (apols if picture upside down/ iPad).
In order to drill a 16mm diameter hole @ 16mm deep into the base of the BMW adaptor that is also shown in the picture, do you think the drill bit in the below link will do the job please/ thanks?
http://www.ebay.co.uk/itm/16MM-HSS-DRILL-B...1c2c78b2bc
Post #210331 15th Sep 2013 8:11am
Page 3 of 4 <1234>
