![]() | Home > Maintenance & Mods (L322) > Indicator flashing --- |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
When you say random, do you mean flickering, or flashing at the same rate as though they were working normally? Got - 2017 SDV8 Autobiography in Loire Blue
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
At different rates, sometimes faster than normal and sometimes slower. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
And it's only the RHS? Got - 2017 SDV8 Autobiography in Loire Blue
Yes just the right 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
I tend to agree that it could be a dodgy relay, or somethings energising it, like a dodgy connection on the steering column or slip ring.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
I did not try provoking it but it was just during "normal" driving not at full lock or any particular angle. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
I actually think what Alan said is the most likely.... If you need anymore wiring info I have it all |
Sounds like one of those problems that'll be hard to trace. Not sure how much a relay would cost, but you have to start somewhere I suppose.
Anyone know where the relay is located? 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
When you are parked, try turning the steering wheel about gently to try and get it to flash. Also, try and Gently tap the indicator stalk and see if it flashes.... Previously..
Did you read any of the info I posted? Previously..
The info refers to the LCM but not the flasher unit 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
