Home > Maintenance & Mods (L322) > Indicator flashing --- |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
When you say random, do you mean flickering, or flashing at the same rate as though they were working normally? Got - 2017 SDV8 Autobiography in Loire Blue
2nd Sep 2013 8:30pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
At different rates, sometimes faster than normal and sometimes slower. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2nd Sep 2013 8:33pm |
And it's only the RHS? Got - 2017 SDV8 Autobiography in Loire Blue
2nd Sep 2013 8:36pm |
Yes just the right 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2nd Sep 2013 8:39pm |
I tend to agree that it could be a dodgy relay, or somethings energising it, like a dodgy connection on the steering column or slip ring.
2nd Sep 2013 8:44pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
2nd Sep 2013 8:52pm |
I did not try provoking it but it was just during "normal" driving not at full lock or any particular angle. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2nd Sep 2013 8:54pm |
I actually think what Alan said is the most likely.... If you need anymore wiring info I have it all Previously..
2nd Sep 2013 9:01pm |
Sounds like one of those problems that'll be hard to trace. Not sure how much a relay would cost, but you have to start somewhere I suppose.
2nd Sep 2013 9:05pm |
Anyone know where the relay is located? 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2nd Sep 2013 9:07pm |
When you are parked, try turning the steering wheel about gently to try and get it to flash. Also, try and Gently tap the indicator stalk and see if it flashes.... Previously..
Did you read any of the info I posted? Previously..
2nd Sep 2013 9:09pm |
The info refers to the LCM but not the flasher unit 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2nd Sep 2013 9:54pm |
