![]() | Home > Technical (L322) > Roughly how much? |
weephillie Member Since: 12 Apr 2010 Location: Sunderland Posts: 16 ![]() ![]() ![]() |
The computer information display on my 52 plate RR has lots of pixels missing. On checking through other posts, it would seem the problem is the ribbon. Has anyone any idea of the cost of having a new ribbon installed so i can read the display again.
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
they are advertised on ebay between 100 - 200 quid dependant if you remove the item or not there is a guy in southampton who does removal but they are all over the uk but be carefull tho some dodgy ones also |
Thanks for the info. Southampton is just about as far away as you could get from me, however there is a link to someone in Preston. I'll check it out. |
SGW did you remove your units and take them if so how easy was it thanks 02 Range Rover HSE Zambezie silver 4.4 |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Hi andyw, to remove the cluster you have to remove the dash top. This is covered in Rave it took me about 1/2 an hour. Once the dash top is off there are 2 torx screws to remove the cluster. I didn't disconnect the battery, just pulled the plugs. Obviously don't turn the ignition on with the cluster removed.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 ![]() ![]() |
Never heard of them, and they are not that far away from me.
