Home > Technical (L322) > Roughly how much?
weephillie
England 2003 Range Rover Vogue Td6 Zermatt Silver
Roughly how much?
The computer information display on my 52 plate RR has lots of pixels missing. On checking through other posts, it would seem the problem is the ribbon. Has anyone any idea of the cost of having a new ribbon installed so i can read the display again.
Thanks in advance.
Post #16827 18th Apr 2010 1:51pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
they are advertised on ebay between 100 - 200 quid dependant if you remove the item or not there is a guy in southampton who does removal but they are all over the uk but be carefull tho some dodgy ones also Thumbs Up
http://shop.ebay.co.uk/i.html?_nkw=range+r...amp;bkBtn= 02 Range Rover HSE Zambezie silver 4.4
Post #16831 18th Apr 2010 3:21pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I used the guy in Southampton for both of ours, took the units to him 3 hours later collected them. He charged a £100 each. Good job and very satisfied, nice to read all of the messages again.
Stewart.
Post #16833 18th Apr 2010 6:15pm
weephillie
Thanks for the info. Southampton is just about as far away as you could get from me, however there is a link to someone in Preston. I'll check it out.
Post #16836 18th Apr 2010 8:12pm
andyw
SGW did you remove your units and take them if so how easy was it thanks 02 Range Rover HSE Zambezie silver 4.4
Post #16837 18th Apr 2010 8:24pm
SGW
Hi andyw, to remove the cluster you have to remove the dash top. This is covered in Rave it took me about 1/2 an hour. Once the dash top is off there are 2 torx screws to remove the cluster. I didn't disconnect the battery, just pulled the plugs. Obviously don't turn the ignition on with the cluster removed.
Stewart.
Post #16950 19th Apr 2010 9:02pm
nbunney
Never heard of them, and they are not that far away from me.
Strange when you look on their web site contact section there is no actual address, so must work from home.
Post #16951 19th Apr 2010 9:17pm
