Home > Technical (L322) > What is a "Companion Camera"?
In my diagnostic screens when doing the 753 hack (as per the updated Wiki today) I see I have a "Companion Camera" and it says this is Fitted. I presume this is a Venture Cam, but the SC doesn't have one.
So what is it?
Does it just mean the car is configured to have one rather than it is actually present?
 Discovery 4 HSE
Post #203744 13th Aug 2013 9:43am
i reckon its the venture cam ...probably old LR firmware being used in the new hard drive setup ... or is an option on yours. ... - .- -.
Post #203748 13th Aug 2013 9:52am
Vogue
Adam,
not sure if this is a companion camera, but check in front of your rear view mirror from the outside looking back from the bonnet, its in the mirror housing. Some RR's have a camera fitted here to record any bad driving / accident data. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #203754 13th Aug 2013 11:06am
Philip
It's VentureCam, just another Video In I suppose.
Post #203760 13th Aug 2013 11:42am
When I select it I just get a black screen. Question Discovery 4 HSE
Post #203761 13th Aug 2013 11:45am
Philip
Presumably because you're not feeding it any video, assuming it's enabled.
Post #203762 13th Aug 2013 11:50am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
This is the inside of a Venture Cam I am currently replacing the battery pack in:
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #203806 13th Aug 2013 3:55pm
solved Thumbs Up ... - .- -.
Post #203809 13th Aug 2013 4:08pm
Guess I could grab the venture cam out of the TDV8 and see if it links up. Genius! Laughing Discovery 4 HSE
Post #203810 13th Aug 2013 4:12pm
Martin
Site Admin
Companion Camera is definitely the Venture Cam.
Post #203811 13th Aug 2013 4:12pm
GraemeC
And there I was hoping it was a 'cleavage cam' Mr. Green 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #203812 13th Aug 2013 4:13pm
ebajema
Didn't Clarkson use the cams for that on a Top Gear a few years ago during a test drive? MY 2010 5.0 SC Galway green and sand interior!!
Post #203814 13th Aug 2013 4:21pm
It doesn't work... Discovery 4 HSE
Post #203819 13th Aug 2013 4:46pm
dave699
Is the space in the upper glovebox still there, where the holder (charger) would be fitted?
That would establish if it is an option on the later models.
Had it, loved it!
2007 Vogue SE TDV8
Post #203855 13th Aug 2013 7:46pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Bringing up a very old thread..... I have just done the very same 753 hack and found the very same thing.
I have no venture cam holder or venture cam.
Did anyone ever find anything more out?
Incidentally I have an "NTSC" which turns in a "PAL" tab when pressed too 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #369712 31st Jan 2016 12:44pm
