![]() | Home > Technical (L322) > What is a "Companion Camera"? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
In my diagnostic screens when doing the 753 hack (as per the updated Wiki today) I see I have a "Companion Camera" and it says this is Fitted. I presume this is a Venture Cam, but the SC doesn't have one.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
i reckon its the venture cam ...probably old LR firmware being used in the new hard drive setup ... or is an option on yours. ... - .- -.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2615 ![]() ![]() |
It's VentureCam, just another Video In I suppose. |
When I select it I just get a black screen. |
Presumably because you're not feeding it any video, assuming it's enabled. |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
This is the inside of a Venture Cam I am currently replacing the battery pack in:
solved |
Guess I could grab the venture cam out of the TDV8 and see if it links up. Genius! |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Companion Camera is definitely the Venture Cam. |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
And there I was hoping it was a 'cleavage cam' |
Didn't Clarkson use the cams for that on a Top Gear a few years ago during a test drive? MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
It doesn't work... Discovery 4 HSE
Is the space in the upper glovebox still there, where the holder (charger) would be fitted?
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
Bringing up a very old thread..... I have just done the very same 753 hack and found the very same thing.
