Home > General > Welcome to fullfatrr.com - introduce yourself here!
Page 170 of 293 <123 ... 169170171 ... 291292293>
welcome to the forum and wiki Rob... Thumbs Up ... - .- -.
Post #385012 3rd May 2016 9:47am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Hi everyone!
I'm Steve, in the United Kingdom!
I've got a 4.6v8 P38, and just picked up a 2003 TD6 L322 with a few problems I am going through Wink
See ya soon...
Post #385186 4th May 2016 1:04pm
Frank
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Hi all , new here so hello to all .I've been reading a lot of posts here to try and resolve my problem with my vehicle. ..
OK , my range rover l322 03 plate wont get off bump stops , some history , owned her for last 10 weeks or so , only put on the road at start of last month , parked at work on slight incline and noticed that it was dipping on drivers side front when i left her about two hours later the whole front end had dropped but car looked level so i though it was ment to do that , came back after about six hours and moved her to flat ground expecting her to level off as she looked like a wedge of cheese , nothing happened. ...reversed into works yard and got out to have a look when i heard a lot of air escape from under car and back end went to bump stops , whole car now level but very low to ground , took to a friend garage who fount that the main air pipe from compressor to air tank had burst , when i took a closer look someone had botched a repair to pipe before i owned vechile and it burst at repair. So fixed the problen but now car wont lift off the bump stops , air suspension inactive message on dash , compressor in boot is new and working ok but car will not tell it to work , bypassed by jumping at relay and filled air tank replaced relay , still nothing , i have a icar 930 reader which tells me fault codes and clears them , when i clear codes on air suspension the compressor kicks in for 2 or 3 seconds and then stops and the faults come back , had it hooked up to a snap on machine wich says it had a communication problem with air suspension ecu , checked ecu and its getting power ok , ride height switch says its at motorway height and lock button lit at all times , tried disconnecting battery and crossing cables but still nothing , checked every fuse and all ok , anybody any ideas plezse ?
Post #385208 4th May 2016 3:26pm
welcome to the forum and wiki.. Thumbs Up
frank , post your questions in the relevant sections and someone should help, or do a search .. ... - .- -.
Post #385211 4th May 2016 3:43pm
Beemergriff
New Member
Hi everybody
As I suspect many have, I found this site while looking for a solution to a problem with my car. I think I have found the answer but registered as I may (will probably) need more help in future.
About me; live in Northamptonshire and actively participate in off-road trails with the All Wheel Drive Club
About my cars; drove BMWs for years, hence Username, and my wife still has one. Current fleet comprises;
L322 Range Rover TD6 SE, 2004 - now about 190k miles
Freelander 1 TD4 manual 5-door, 2004
BMW 330ci auto, 2001
RR Classic based off-roader, chassis cut to 88" wheelbase with Whitbread frame and body panels
Thanks for the advice gleaned so far
Regards
Andrew
Post #385516 6th May 2016 11:09am
frenshy
Hi All
Jim here - recently bought my first L322. Previously owned a few P38 and very knowledgable about the common issues having dealt with suspension, alarm/immobiliser, cruise control, boot leaks, and plenty of other usual P38 probs.
Now bought a Dec2006 (07 model with key up on dash) TDV8, 90k miles. I have inherited a couple of issues with it Ive already started getting stuck into - but hoping I wont have as many ongoing probs to deal with as on my P38s !!
Post #386435 11th May 2016 5:22pm
smiler289
Hi folks!
New owner of a used 03 l322 and we love it. But it does have problems 😕
Post #386474 11th May 2016 6:23pm
welcome all Thumbs Up ....theres loads of info about FF's in our wiki and of course using our search function... ... - .- -.
Post #386476 11th May 2016 6:25pm
Andir
South Africa
Hi All
Hello from Johannesburg.
Andi here and just bought a 08 TDV8 Vogue. I gleaned a lot of information from you here before buying. I was lucky to get a problem car really cheap and being ready for turbos it turned out to be an air hose. Pheew.
Ive owned a lot of rangies in the past and look forward to being part of the L322 club now
Post #386573 12th May 2016 5:38am
Dave
Hello for Norfolk
Hello, and thanks to all for the contents on this forum.
I'm soon to be buying a 2012 RR Vogue, pick it up next week, can wait.
I'll post some pics when shes home
Post #386652 12th May 2016 1:58pm
mariner30
United Kingdom 2003 Range Rover SE Td6 Rimini Red
Evening everyone. Like many others I have just become the owner of an 03 plate L322 which has the usual problems but only 90k registered. Came here via a link to see the faults caused by a failed Final Stage Resistor. Pretty sure mine is duff!
I'll be back!
Post #386753 12th May 2016 9:18pm
pinkfoot
Morning.
New member ,well I am not new ,I am 52 but my membership is.
I don't have a RR yet as my wife insists I sell my defender first.
I really like the one Smutt has for sale. Hoping it doesn't sell just yet!
Post #387465 17th May 2016 9:58am
thanks for all your introductions..welcome to the forum and wiki.. Thumbs Up ... - .- -.
Post #387475 17th May 2016 11:25am
Kimbo
Hi all
Just got my first Range Rover,a 2012 Westminster,so thought I would join up with this forum,always a good place for shared knowledge and you guys seem like a friendly bunch Wink
Kimbo Smile
Post #387484 17th May 2016 12:24pm
bjwerkman
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Hi everyone - new member - great forum.
Impressive collection of information & user experience.
Post #387720 18th May 2016 6:34pm
