Home > General > Welcome to fullfatrr.com - introduce yourself here! |
quelo31 Member Since: 19 Aug 2015 Location: Madrid Posts: 1 |
Hi all,
19th Aug 2015 8:21pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Hi and welcome newbies
19th Aug 2015 9:45pm |
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 |
Hi all, been lurking round here for a couple of weeks soaking up the knowledge having decided to take the plunge and upgrade my Evoque to its far bigger brother.
22nd Aug 2015 1:52pm |
sherman Member Since: 23 Aug 2015 Location: L'Isle Jourdain Posts: 71 |
Hi Peeps
23rd Aug 2015 9:40am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Hi guys I'm thinking of getting an 06 Vogue. Had a test drive and was smitten. Now I've had a chance to sleep on it I', sure it is what I want however I would like some guidance on the following -
23rd Aug 2015 3:17pm |
23rd Aug 2015 3:57pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
Perfectly normal and if the need last longer than 6 weeks it means you are perfectly normal and do not need to see a doctor.
23rd Aug 2015 4:08pm |
Jcapel Member Since: 24 Aug 2015 Location: Mittagong Posts: 4 |
Hallo everyone, I have just bought a white 2007 supercharged 4.2 Range Rover Vogue and I am very happy with the purchase! I live in NSW...with my car, which is yet to be named...probably call her Pandora as I had difficulty in opening her cubby box. I have a question for anybody...the rear camera worked once fine...but has never worked again...I have checked the fuse and removed the neg terminal to reboot the software and the problem was not fixed. Could it be the camera has finally died or is it more like ly to be another problem which I am unaware of. A new camera costs $AUD 1345 to install by Landrover Australia. Can anyone help me please. The car has done 115000 Kms approx. Many thanks. Jonno |
24th Aug 2015 9:14am |
24th Aug 2015 9:21am |
Search on here for " Hidden menu" this will teach you how to access a diagnostic screen to see if you camera actually works and the problem is elsewhere , Land Rover Australia have an almost criminal attitude to roorting prices usually four time rest of the world pricing , further down on the list of topics is one called Duckworth Parts it's a Land Rover dealer in the UK who will post out parts at proper prices
24th Aug 2015 10:32am |
Thank you Axle for your information on the diagnostics. I have done both diagnostic s on the MY2007 RR and list diagnostics say there are no errors. Second dignostics on Video input does not show up camera picture, but says it is fitted.
24th Aug 2015 11:45pm |
TV is PAL here but the reverse camera is NTSC ( why do it the easy way and have them the same )
25th Aug 2015 1:52am |
Thanks again axle. Can these cameras be taken apart and repaired? Can a non Range Rover/Jaguar camera be used. That is do you know if there are compatible cameras for this 2007 RR s/c...at a lot cheaper, or are Land rover cameras specific and therefore unique....adaptors/ software/sizing etc. Cheers once again....by the way, do you know where I can purchase a rear entertainment remote control unit, that was missing when I purchased the RR? So many questions...must be a bit of a pain! |
25th Aug 2015 2:04am |
I have never done it so I can only speak of what I have heard here but a camera from the UK won't be too bad and with a bit of Dremel work and a soldering iron you can fit a higher definition camera from a later FullFat and some have even fitted after market cameras with a bit of work but one plan would be to get a rear spoiler from a wreck and re spray and fit that then all you do is connect the camera .
25th Aug 2015 2:27am |
