![]() | Home > Technical (L322) > MOT Failure |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 ![]() ![]() |
That sorts it then, if i cant fix it today - they're off |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
http://webarchive.nationalarchives.gov.uk/...ghting.pdf
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I have been quoting from the 4th edition of the testers manual (Copyright 2011).
i've looked at the rave diagram and can see with my uneducated eyes that the wipers get a feed from a "header", can anyone tell me what the "header" is or does?
The relevant section from Dave's pdf, leaving us in no doubt . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
I couldn't do that ^ from my iPhone |
Here is what I believe to be the correct wiring diagram for your car (nicedayforit might chip in at some point) which is slightly different to your one:
My guess is it's either an earth or the relay (whereever that is?) if you are getting power after the fuse..... Other useful stuff from Rave: . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
well the o/s motor works but no water so def has power passed fuse. This seems to be the relay: http://britishparts.co.uk/products/8964-relay-YWB000060 and possibly worth changing as i had the header tank and screen wash filler neck off to check the earths and they where very shiny and clean. I've pulled fuse 28, switched on and off =, replaced fuse but no help. I've disconnected the battery and terminal touched to no avail. |
Do "we" know where the headlamp wash/wipe relay IS ?
according to RRPhil on rangerovers.net its to the left of the passenger glove box (c2031):
2003 4.4 LPG, Vogue, Silver |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Well using logic here, if one wiper is working and the other isn't then the relay itself won't be the problem, the output of the relay is common between the two, if the relay was knackered then BOTH wipers wouldn't work.
The annoying part of fixing must be that the flaming headlamp wipers only work with the lights on and once every six wash wipes from the main wipers. |
That was a quick late night post, so to update:
