Home > Technical (L322) > tdv8 metallic whine
Page 1 of 3 123>
atc
tdv8 metallic whine
hi everyone. Finally got my vse tdv8 Cool and i am really chuffed with it. there are a couple of 'noises' i wondered if a fellow owner could confirm are normal. the first one is a high pitched very metallic sounding whine (not the turbos - noticably louder) when the car is under heavy type acceleration. the second is a low pitched moan around 2k rpm with a feel of mild vibration coming from infront of the bulkhead when under medium + load.
sorry if i sound like a numbty! this is my first rangie - its still under lr warranty so i want to make sure i get any probs sorted before its me paying the bills!
thanks Thumbs Up
Post #16395 9th Apr 2010 8:28pm
Olders
Did anyone have any thoughts on this?
I too have the second of these noises - i.e. a low pitched moan/groan when engine under load between 2000 and 3000 rpm. This is also accompanied by a mild vibration coming up through the pedals, drivers footwell, bulkhead. This is not really noticeable below 1900/2000 rpm and above 3000 rpm.
Am going to get the fluids changed (gearbox, transfer box, front diff) to see if that helps - probably worth it anyway on a 07MY TDV8 (ZF 'box I think?) at 57k miles, no?
There also seems to be a bit of a "bump/thump" when changing from 1st to 2nd under medium to high throttle and another that sometimes happens when you are accelerating under medium throttle and then lift close to the gear change point.
Also, just occasionally, the gear changes seem a little random/non-linear, almost exclusively under medium or low throttle settings - i.e. doesn't step down for a few secs with 60/70% throttle input when at low revs in a high gear or changes down then up again within a short space of time. Almost as if the 'box doesn't know what gear it should be in / getting a bit confused. Sometimes also get this "confusion" after a period of spirited driving with large throttle openings followed by total lift off followed by large throttle opening when in "D" as opposed to "S".
Thoughts so far are:
1. All above are normal behaviour, not to worry.
2. Gearbox, transfer box or front diff on the way out
3. Trans fluids need changing
4. I have only done circa 5k miles in the car - maybe the 'box is still "learining" my driving style, which may be different from the previous owner's
Any help/guidance/thoughts/observations on the above much appreciated!!
Thanks in advance! -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #67055 5th Jun 2011 1:54pm
allisong
Most of those issues can be easily fixed by loading updated calibration software (via IDS) for the TCM and ECM (transmission control module and engine control module).
I did this a while back and had similar issues and they have all gobe.
Post #129109 3rd Jul 2012 8:03am
Olders
Allisong,
That is interesting.
I have had the transmission update done and changed the gearbox and diff fluids (no problems with oil quality) that did improve (although not totally extinguish) most of the transmission 'bump' and gear 'hunting' issues I mentioned above however the groaning noise and vibration at 2k to 2.5k revs is still there and has got worse. Is it this that you were referring to when you said that it was cured by an ECM update?
Many thanks. -----------------------------------------------
Post #129134 3rd Jul 2012 8:30am
DMRR
The 'groan' at those revs, are you 100% you are not confusing the V8 exhaust note for a problem? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #129145 3rd Jul 2012 9:09am
Olders
Very Happy 110% sure!
Firstly, it is accompanied by a high frequency vibration through the front bulkhead and
Secondly, it wasn't there when I acquired the car but is now.....
If you could experience it, I promise you would not mistake it for exhaust noise!
Thank you for your thought though.
Cheers. -----------------------------------------------
Post #129148 3rd Jul 2012 9:20am
DMRR
Possibly loose heatshield? I'm not sure if there any - but that would be roughly where they are (if they exist!). The only other thing that groans is the FBH (this will cut in at temps below 16 I think), and is there to assist in bringing the coolant up to temperature (and providing a means to heat the cabin!).
Does it do it all the time, or just initially? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #129152 3rd Jul 2012 9:52am
Olders
Definitely not the FBH. I know that groaning. This is different. More of a drone than a groan (if that is not too subjective!). And, as you say, the FBH noise goes away when everything is up to temp.
If anything, my symptoms aren't there to begin with (i.e. when cold) and only become very evident when you have been driving for a bit and everything is fully warmed up.
Doubt it is a loose heat shield either. I think it would be a higher pitched, more 'tinkly' sound if that was it. This sounds more engine (possibly mounts?) / drivetrain related to me. -----------------------------------------------
Post #129155 3rd Jul 2012 10:14am
DMRR
Does it occur under load, i.e. if you rev up to 2.245k rpm in the driveway, does it still happen? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #129161 3rd Jul 2012 10:29am
Olders
No. Only under medium or high throttle input when transmission is engaged. I.e. drivetrain under load. -----------------------------------------------
Post #129164 3rd Jul 2012 10:33am
i think you might have answered your question there...it does sound [no pun] like something to do with the drivetrain.. ... - .- -.
Post #129166 3rd Jul 2012 10:39am
DMRR
If it was my old D1 .. I'd suggest checking the UJ's Laughing
Something must be a bit unhappy in the drivetrain. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #129167 3rd Jul 2012 10:41am
Olders
Indeed. But which part is the question. And what to do about it!
It has been like that now for nearly 20k miles. If it was the gearbox or torque converter about to go pop, surely that would have happened by now.
FYI, current mileage is about 76k. -----------------------------------------------
Post #129168 3rd Jul 2012 10:43am
get a couple of garages to take it on a test drive and get some quotes... ... - .- -.
Post #129172 3rd Jul 2012 10:48am
Olders
I think you are probably right Stan. I am just nervous of spending fortunes on incorrect diagnosis and consequent unnecessary work! -----------------------------------------------
Post #129174 3rd Jul 2012 11:07am
Page 1 of 3 123>
