Home > Technical (L322) > tdv8 metallic whine |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 |
Did anyone have any thoughts on this?
5th Jun 2011 1:54pm |
allisong Member Since: 28 Jun 2011 Location: UK Posts: 9 |
Most of those issues can be easily fixed by loading updated calibration software (via IDS) for the TCM and ECM (transmission control module and engine control module).
3rd Jul 2012 8:03am |
Allisong,
3rd Jul 2012 8:30am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
The 'groan' at those revs, are you 100% you are not confusing the V8 exhaust note for a problem? Land Rover Addict
3rd Jul 2012 9:09am |
110% sure!
3rd Jul 2012 9:20am |
Possibly loose heatshield? I'm not sure if there any - but that would be roughly where they are (if they exist!). The only other thing that groans is the FBH (this will cut in at temps below 16 I think), and is there to assist in bringing the coolant up to temperature (and providing a means to heat the cabin!).
3rd Jul 2012 9:52am |
Definitely not the FBH. I know that groaning. This is different. More of a drone than a groan (if that is not too subjective!). And, as you say, the FBH noise goes away when everything is up to temp.
3rd Jul 2012 10:14am |
Does it occur under load, i.e. if you rev up to 2.245k rpm in the driveway, does it still happen? Land Rover Addict
3rd Jul 2012 10:29am |
No. Only under medium or high throttle input when transmission is engaged. I.e. drivetrain under load. -----------------------------------------------
3rd Jul 2012 10:33am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
i think you might have answered your question there...it does sound [no pun] like something to do with the drivetrain.. ... - .- -.
3rd Jul 2012 10:39am |
If it was my old D1 .. I'd suggest checking the UJ's
3rd Jul 2012 10:41am |
Indeed. But which part is the question. And what to do about it!
3rd Jul 2012 10:43am |
get a couple of garages to take it on a test drive and get some quotes... ... - .- -.
3rd Jul 2012 10:48am |
I think you are probably right Stan. I am just nervous of spending fortunes on incorrect diagnosis and consequent unnecessary work! -----------------------------------------------
3rd Jul 2012 11:07am |
